APM change footer position
Hello,
Is there a way to change position of footer to be more higher ? In IE full screen, I can see the footer but in chrome/Firefox the footer is too down.
Thanks,
You can modify the css and the logon.inc and various other pages to customize the user experience. You will do this in the Advanced Customization section of the APM module.
Your best bet is to discuss with a web designer your needs and have them help you modify the pages. If you run into any issues please let us know and we can help you out.
-Seth
