I heard you can install APM under LTM with partial license. Does anyone know any document on it.
Check out . You can enable the APM module in a limited state, which will allow up to 10 concurrent users.
You’ll just need to relicense your box and provision APM alongside LTM. There’s some other documents referenced in the article on this as well
