APM - apply macro rule based on a specific link selection
I’m not even sure where to start with this question. I have an Access Policy using the F5 as a saml sp. It’s relatively simple. The user hits the F5 gets the saml auth (which sends the request to an external IDP). Gets the response back and am doing a variable assign so that I can pass the username on the serverside for kerberos authentication. ALL OF THIS WORKS FINE. However i have an application that is linked to and served up via an iframe within sharepoint that doesn’t support kerberos. Soooo, I need to make it so that when users who have already authenticated and are in sharepoint click this specific link that they are brought to a logon page where they can put their AD creds in and can then be sent to the page (that is displayed within sharepoint).
I believe the way to do this is to add an AD auth macro to my existing policy, but I can’t figure out how to make it work only when that specific URI is called.
Does your application support CAS (Central Authentication Service)
some customer deploying application that does not support Kerberos configure CAS (which support Kerberos).
