Hei community,
We have an issue in apm saml application after the os upgrade to 17.1.1.3 . Our F5 is sp and azure working as an IDP. Now application not working and I need your expertise to find solution. This is in test environment.
Yov
Hei community,
Yov
It’s failed to parse assertion, error : $fmt
Yove
Hi @yove_07
t’s an expected issue in 17.x , please execute the work around as per KB
Also please check with azure team and confirm if assertion is signed by azure or not. It should be signed by azure and remove configuration from F5 as per the KB
Br
Aswin
Yes it a fix. Thank you very much, saved our day
