Environment: v11.1 HF1 LTM and APM
Hi all,
I am running into a strange error from APM that I can’t find any documentation on:
The resource you are looking for is temporarily unavailable.
The cause may be an incomplete access policy evaluation. Please continue to finish your access policy in the previous browser window, and close this current window immediately.
What I am attempting to do is introduce a second-factor authentication system into my APM flow. The second-factor system runs on different servers in a separate pool on my LTM. This is my current policy flow:
start → logon page → AD auth → iRule Event → message box → sso credential mapping → allow
(all fallback branches fall to deny)
So in that iRule event, I’m trying to trigger the intercept to my second-factor handling after the first factor succeeds. The second-factor system will post back to my protected VS with a fake URI (/fromSF) to indicate it has completed successfully. This is the iRule I’ve created so far:
when HTTP_REQUEST priority 700 {
log local0. "--- URI is [HTTP::uri]"
set apm_cookie [HTTP::cookie value MRHSession]
if { $apm_cookie != "" && [ACCESS::session exists $apm_cookie] } {
log local0. "*** We have a valid APM session cookie"
log local0. "*** We DO NOT have a valid APM session cookie yet!"
if { [HTTP::uri] eq "/goToSF" } {
log local0. "*** goToSF URI received; trying to get the SF form to display; so changing uri and disabling APM for this event"
ACCESS::disable
HTTP::uri /abc/Default2.htm
pool pool_SF
ACCESS::enable
log local0. "*** setting pool to protected app"
pool pool_APP
if { [HTTP::uri] eq "/fromSF" } {
log local0. "*** Completed the second factor successfully, we now redirect them to start page of protected app"
HTTP::respond 301 Location /def
when HTTP_RESPONSE {
log local0. "*** in http response"
when ACCESS_POLICY_AGENT_EVENT {
if { [ACCESS::policy agent_id] eq "intercept_for_sf" } {
log local0. "*** tricking us back into http_request"
ACCESS::session data set session.custom.sf_result 0
HTTP::respond 301 Location /goToSF
This is what I see in my log file:
Apr 13 11:37:08 tmm3 info tmm3[24171]: Rule /Common/APP-irule : --- URI is /
Apr 13 11:37:08 tmm3 info tmm3[24171]: Rule /Common/APP-irule : *** We DO NOT have a valid APM session cookie yet!
Apr 13 11:37:08 tmm3 info tmm3[24171]: Rule /Common/APP-irule : *** setting pool to protected app
Apr 13 11:37:12 tmm3 info tmm3[24171]: Rule /Common/APP-irule : *** tricking us back into http_request
Apr 13 11:37:12 tmm3 err tmm3[24171]: 011f0007:3: http_process_state_prepend - Invalid action EV_SINK_HEADER during ST_HTTP_PREPEND_HEADERS (Client side: vip=/Common/VS_APP profile=http pool=/Common/pool_APP client_ip=1.1.1.1)
Apr 13 11:37:12 tmm info tmm[24168]: Rule /Common/APP-irule : --- URI is /goToSF
Apr 13 11:37:12 tmm info tmm[24168]: Rule /Common/APP-irule : *** We have a valid APM session cookie
Apr 13 11:37:12 tmm info tmm[24168]: Rule /Common/APP-irule : *** goToSF URI received; trying to get the SF form to display; so changing uri and disabling APM for this event
Apr 13 11:37:12 tmm info tmm[24168]: Rule /Common/APP-irule : *** in http response
Apr 13 11:39:28 tmm1 info tmm1[24169]: Rule /Common/APP-irule : --- URI is /fromSF
Apr 13 11:39:28 tmm1 info tmm1[24169]: Rule /Common/APP-irule : *** We have a valid APM session cookie
Apr 13 11:39:28 tmm1 info tmm1[24169]: Rule /Common/APP-irule : *** setting pool to protected app
Apr 13 11:39:28 tmm1 info tmm1[24169]: Rule /Common/APP-irule : *** Completed the second factor successfully, we now redirect them to start page of protected app
Apr 13 11:39:28 tmm1 info tmm1[24169]: Rule /Common/APP-irule : --- URI is /def
Apr 13 11:39:28 tmm1 info tmm1[24169]: Rule /Common/APP-irule : *** setting pool to APP
After clicking the submit button in the second-factor app, it waits for the timeout to expire and then finishes the rest of the log messages. The last message in the session report for APM is “Session variable ‘session.logon.page.errorcode’ set to ‘0’”. I never see the message box from the policy.
I’m sure I’m doing something goofy, I just don’t know what it is?
Thanks,
Jen
