APM AD Auth and Trusted Domains
Hi there,
I have a domain trust between acme.com and contoso.com. The APM lives in the acme.com and can authenticate users against this domain using AD Auth. With the trust in place I want to allow users in the contoso domain to authenticate through the APM.
AAA AD server is configured for acme.com AAA AD Trusted Domain is configured for contoso.com with acme.com AAA selected and configured as the Root.
In the VPE the AD Auth is pointing to acme.com with cross domain support enabled. The trusted domains is grayed out.
What am I missing?
I’m guessing the Trusted Domains options is greyed out because you’ve selected a AAA server in the AD auth config. You can use one or the other.
Mark,
Your settings in VPE for AD Auth should be:
Server: None
Trusted Domains:
Cross Domain Support: Enabled
With a configured Server you cannot set the domain trust, just switch it back to None and the Trust should be selectable.
Best
René
