I currently have a customer that is switching from an Apache Proxy server with Apache Virtual Hosts to and F5 BigIP LTM. I would like to know if anyone has eve done this and/or if it is possible to use the Apache Virtual Hosts and load balancing.
Matt
I don’t see why it wouldn’t be possible, on a general level. Is there a more specific task you’re trying to perform?
Colin
Thanks for you reply Colin. To be more specific, here is what they are trying to do.
on the outside they have something like https://mywebsite.bb.unc.edu and then internally they have https://hostname.bb.unc.edu . They are currently getting it done by using Apache Virtual hosts.
Hi, Any have a response for this?
I resolve this in HTTP changing the servername in httpd.conf to the host domain in VS but using HTTPS the aplication response but the content is incomplete. I change the servername in ssl.conf in the apache configuration.
hoolio
October 5, 2011, 9:23pm
5
Thanks hoolio,
Can you have an example to do this:
- have 7 server with apache named: www1.example.com , www2.example.com … www7.example.com
- have 1 pool in the F5 for this with member 192.168.1.1:443…192.168.1.7:443
- the defaul gw of servers is F5
- have 1 VS 203.1.1.1:443 with ssl termination and ssl server.
- the web page for the client is www.example.com , in DNS: www.example.com → 203.1.1.1
needed: irule that rewrite the url go to pool via round robin or other:
if www1 is selected → rewrite www.example.com/xyz for www1.example.com/xyz
if www2 is selected → rewrite www.example.com/xyz for www2.example.com/xyz
if www3 is selected → rewrite www.example.com/xyz for www3.example.com/xyz
if www7 is selected → rewrite www.example.com/xyz for www7.example.com/xyz
Thanks hoolio,
hoolio
October 5, 2011, 10:28pm
8
For that, you can create a datagroup which maps the server IPs and corresponding hostnames. Then in the HTTP_REQUEST_SEND event, you can rewrite the host header:
For 9.4.x, you can use this example:
http://devcentral.f5.com/wiki/iRules.rewrite\_host\_header\_to\_server\_name.ashx
For 10.x, you could use a name=value string datagroup and the class command to do the lookup:
http://devcentral.f5.com/wiki/iRules.class.ashx
Aaron
hoolio
October 5, 2011, 10:30pm
9
Another option:
If you can update the virtual host definition in apache to accept the server IP in the host header, then you can eliminate the datagroup and lookup:
from: http://devcentral.f5.com/wiki/iRules.http_request_send.ashx
when HTTP_REQUEST_SEND {
Need to force the host header replacement and HTTP:: commands into the clientside context
as the HTTP_REQUEST_SEND event is in the serverside context
clientside {
Replace the HTTP host header with the connected server IP and port
HTTP::header replace Host "[IP::server_addr]:[TCP::server_port]"
Aaron
thanks, Hoolio.
The irule works fine when a default pool is selected in the GUI but when I add in the irule an pool selection the irule the aplication response but with errors in the content.
I am using V10.2.1 and the irule is:
bigip.conf:
class nombre {
host 192.168.2.10 { “www1one.example.com ” }
host 192.168.2.20 { “www2one.example.com ” }
host 192.168.2.30 { “www1two.example.com ” }
host 192.168.2.40 { “www2two.example.com ” }
host 192.168.2.50 { “www1one.test.com ” }
host 192.168.2.60 { “www2one.test.com ” }
irule:
if { [HTTP::host] equals “www.example.com ” and [HTTP::uri] starts_with “/one” } {
pool Pool_Example_One }
elseif { [HTTP::host] equals “www.example.com ” and [HTTP::uri] starts_with “/two” } {
pool Pool_Example_Two }
elseif { [HTTP::host] equals “www.test.com ” and [HTTP::uri] starts_with “/one” } {
pool Pool_Test_One }
set host_debug 1
clientside {
if {$host_debug}{log local0. “[IP::client_addr]:[TCP::client_port]: New [HTTP::method] request to [HTTP::host][HTTP::uri]”}
set host_header_value [class match -value [LB::server addr] equals nombre]
if {$host_debug}{log local0. “[IP::client_addr]:[TCP::client_port]: Looked up [LB::server addr], found: $host_header_value.”}
if {$host_header_value ne “”}{
HTTP::header replace Host $host_header_value
if {$host_debug}{log local0. “[IP::client_addr]:[TCP::client_port]: Replaced Host header with $host_header_value.”}
nitass
October 8, 2011, 9:33am
11
it seems working fine to me. what was the error?
[root@iris:Active] config b virtual bar list
virtual bar {
snat automap
destination 172.28.17.33:http
ip protocol tcp
rules myrule
profiles {
http {}
tcp {}
[root@iris:Active] config b rule myrule list
rule myrule {
if { [HTTP::host] equals "www.example.com" and [HTTP::uri] starts_with "/one" } {
} elseif { [HTTP::host] equals "www.example.com" and [HTTP::uri] starts_with "/two" } {
} elseif { [HTTP::host] equals "www.test.com" and [HTTP::uri] starts_with "/one" } {
pool Pool_Test_One
set host_debug 1
clientside {
if {$host_debug} {log local0. "[IP::client_addr]:[TCP::client_port]: New [HTTP::method] request to [HTTP::host][HTTP::uri]"}
set host_header_value [class match -value [LB::server addr] equals nombr]
if {$host_debug} {log local0. "[IP::client_addr]:[TCP::client_port]: Looked up [LB::server addr], found: $host_header_value."}
if {$host_header_value ne ""} {
if {$host_debug} {log local0. "[IP::client_addr]:[TCP::client_port]: Replaced Host header with $host_header_value."}
[root@iris:Active] config b class nombr list
class nombr {
host 10.10.70.201 { "www1one.example.com" }
host 10.10.70.202 { "www1two.example.com" }
host 10.10.70.211 { "www1one.test.com" }
1) www.example.com/one
New TCP connection 1: 172.28.16.50(37170) <-> 172.28.17.33(80)
1318066155.9017 (0.0171) C>S
GET /one HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Host: www.example.com
Accept: */*
New TCP connection 2: 10.10.72.30(37170) <-> 10.10.70.201(80)
1318066155.9021 (0.0003) C>S
GET /one HTTP/1.1
Host: www1one.example.com
Accept: */*
2) www.example.com/two
New TCP connection 1: 172.28.16.50(37200) <-> 172.28.17.33(80)
1318066205.3706 (0.0005) C>S
GET /two HTTP/1.1
Accept: */*
New TCP connection 2: 10.10.72.30(37200) <-> 10.10.70.202(80)
1318066205.3711 (0.0003) C>S
GET /two HTTP/1.1
Host: www1two.example.com
Accept: */*
3) www.test.com/one
New TCP connection 1: 172.28.16.50(37217) <-> 172.28.17.33(80)
1318066233.1738 (0.0005) C>S
GET /one HTTP/1.1
Host: www.test.com
Accept: */*
New TCP connection 2: 10.10.72.30(37217) <-> 10.10.70.211(80)
1318066233.1743 (0.0002) C>S
GET /one HTTP/1.1
Host: www1one.test.com
Accept: */*
Logging the irule and adding a else sentence in the irule I discover querys to the url: www.example.com/images within the /one and /two client querys.
This is a configuration in the application and do not have a solution because some code in /images is shared for /one and /two and other not.
The code is "burned"in the application and the only solution that occurred me is to differenciate the /one and /two applications in the host parameter with www.example.com/one and www2.example.com/two
