AOM on a VCMP Guest
Is there any way to get an AOM-like interface on a VCMP guest to be able to check display on reboots for instance ?
VCMP Host is running BIG-IP 5250v on 11.5.3 and VCMP Guests are 11.6.0 HF4.
Thanks,
You can use the vconsole utility from the host. It’s documented here:
Basically you give it the name of the guest (Not the hostname of the guest) like so:
vconsole ltm1guest 1
You will want to read the solution article as it details details such as how to disconnect from the console when you are done.
