anyone using dashboard platform to monitor (restful) BIGIPs (and other stuff)
hi
I’m looking for a solution to create a dashboard for the operations team. In the goal of monitoring their BIGIP devices with restful API.
Dashing seemed an easy/great solution but after seeing the limitation that IE is not supported, I need to find an alternative. Any input (with their pro/cons) warmly welcomed.
Goal: an easy-to-install-and-configure platform that provides easy customization and flexibility.
Alex
Why re-invent the wheel? There are plenty of SNMP-based enterprise monitoring dashboards…
