Any way to argument TCP Option per HTTP Request on Server Side (OneConnect case)
Assuming ONECONNECT case server side request and response are serialized, do we have a way to set custom TCP::option per packet at certain HTTP Egress Event? What’s good EVENT to use?
I haven’t proved whether this works or not.
Thanks for your thought!
I believe v11.6 introduces some further TCP option/parameter related commands but I’ve not idea what events they are support in at the moment.
This may help somewhat: DevCentral - An F5 Technical Community
I found this TCP enhancement from 11.6.0 release note
TCP Enhancements This release includes several user-configurable TCP enhancements to optimize traffic, including early retransmission, tail loss probe, and two additional congestion control algorithms.
Probably not what you mentioned.
Thanks!
I was referring to this text:
Dynamic TCP tuning
Modification of TCP profile parameters via iRules.
No detail and that being the case perhaps it means all and any parameters can be changed which might be useful for you?
