Hey guys -
Thanks. I can confirm that I am using the standard HTTP profile and then stardard TCP profile that comes with the F5. I am running the F5s on v 9.4.3, but plan to upgrade to 9.4.5 in the near future. Clients are all external. Here is the http profile:
profile http http {
basic auth realm none
oneconnect transformations enable
header insert none
header erase none
fallback “xxx”
compress disable
compress prefer gzip
compress min size 1024
compress buffer size 4096
compress vary header enable
compress http 1.0 disable
compress gzip memory level 8k
compress gzip window size 16k
compress gzip level 1
compress keep accept encoding disable
compress browser workarounds disable
compress cpu saver enable
compress cpu saver high 90
compress cpu saver low 75
response selective chunk
lws width 80
lws separator none
redirect rewrite none
max header size 32768
max requests 0
pipelining enable
insert xforwarded for disable
adaptive parsing enable
ramcache disable
ramcache size 100mb
ramcache max entries 10K
ramcache max age 3600
ramcache min object size 500
ramcache max object size 50K
ramcache ignore client cache control all
ramcache aging rate 9
ramcache insert age header enable
compress content type include
“text/”
“application/(xml|x-javascript)”
TCP profile is also the standard one:
profile tcp tcp {
reset on timeout enable
time wait recycle enable
delayed acks enable
selective acks enable
proxy max segment disable
proxy options disable
deferred accept disable
ecn disable
limited transmit enable
nagle enable
rfc1323 enable
slow start enable
bandwidth delay enable
ack on push disable
idle timeout 300
time wait 2000
fin wait 5
close wait 5
send buffer 32768
recv window 32768
keep alive interval 1800
max retrans syn 3
max retrans 8
Thanks for the help!
