Ansible playbook error
Need help in Ansible playbook.
Trying to run a basic playbook to fetch facts and command, but it keeps popping error. Can please anyone help.
Playbook 1
- name: Collect
  bigip_device_facts:
    gather_subset:
      - interfaces
      - vlans
    provider:
      server: x.x.x.x
      user: <username>
      password: <password>
Error
 [WARNING]: provided hosts list is empty, only localhost is available. Note that the implicit localhost does not match 'all'
ERROR! 'bigip_device_facts' is not a valid attribute for a Play
The error appears to have been in '/ansible-01/playbook.yml': line 1, column 3, but may
be elsewhere in the file depending on the exact syntax problem.
The offending line appears to be:
- name: Collect
  ^ here
Playbook 2
- name: run show version
  bigip_command:
     commands: show sys version
     provider:
        server: x.x.x.x
        user: <username>
Error
ERROR! 'bigip_command' is not a valid attribute for a Play
The error appears to have been in '/ansible-01/playbook1.yml': line 1, column 3, but may
  ^ here
Thanks,
Aditya
Hello Aditya,
It seems that your playbook structure is incorrect. You’re missing the host and task information.
You should try the following:
-  hosts: localhost
   connection: local
   gather_facts: no
   tasks:
   - name: Collect
     bigip_device_facts:
       gather_subset:
         - interfaces
         - vlans
       provider:
         server: x.x.x.x
         user: <username>
Be careful to respect the indentation.
Best,
Mael
