Ansible bigip_pool module and definding monitor path
I am newbie with using Ansible and F5 modules, I am trying to assign a monitor to a pool but seems the module is not parsing the path of the monitor ?. My monitors are in a different partition compared to my pools. I am defining in my playbook:
  • partition: “PROD”
  • monitors: “/Common/TCP-HO-00080”
The error I get when I run the playbook is: The monitor template /PROD/TCP-HO-00080 was not found.\“,\“errorStack\”:[],\“apiError\”:3}'”
Has anybody seen this issue before or do I need to define the monitor differently ?
