I have a requirement to forward mms traffic to a specific mmsc, and perform header enrichment.
I have an irule to forward traffic to a specific ip address. What irule can be used to combine that with header enrichment.
This is my current irule.
when HTTP_REQUEST { if { [HTTP::host] equals “10.199.212.15” && [HTTP::uri] equals “/servlets/mms”} { pool mmsc_pool } }
Q. Do you want to add client ip in header or specific words? if client IP then follow below irule.
Please test it in your environment and let us know if any issue.
if { [HTTP::host] equals "10.199.212.15" && [HTTP::uri] equals "/servlets/mms"} {
HTTP::header remove X-Forwarded-For
HTTP::header insert X-Forwarded-For [IP::client_addr]
pool mmsc_pool
Thank You f5_rock, The header enrichment i want to perform is to reveal the MSISDN information. Can it be achieved
which type of value you store in MSISDN. update the sample here. I can see many irule related to MSISDN on devcentral.
the only MSISDN information needed for now is the phone number,eg, 08034567892
The HTTP header enrichtment for MMS traffic is typically done on the WAP2 gateway, which is an network enforced HTTP proxy with a RADIUS accounting proxy, allowing to get all RADIUS packets from the GGSN as the PDP/IP conect for the client is established. Then the gateway enriches the HTTP headers with any RADIUS provided values, i.e. Calling-Station-Id woudl be your MSISDN for the MMSC. See Kannel WAP gateway for an open source WAP gateway that can do this.
