This is definitely a newbie question, so apologies in advance!
I have a context switch within an irule like so:
“/stuff/place*” {
pool my_pool
return
I would now like to point /stuff* to the same pool, but in the following manner:
“/stuff*” {
if { some conditions } {
HTTP::redirect “http://www.site.com/overhere/ ”
pool my_pool
My question is, can the two context switches co-exist within the same irule or will the switch for /stuff* overrule the entry for /stuff/place* ?
TCL evaluates switch statements in order, so you should put the more specific towards the top and the less specific at the bottom…
Thanks for the reply Brian. I’ll test that and let you know how it goes.
nitass
September 15, 2011, 5:19pm
4
[root@orchid:Active] config b rule myrule1 list
rule myrule1 {
switch -glob [string tolower [HTTP::uri]] {
"/stuff/place*" {
log local0. "URI is [HTTP::uri], /stuff/place* is triggered."
"/stuff*" {
log local0. "URI is [HTTP::uri], /stuff* is triggered."
default {
log local0. "URI is [HTTP::uri], default is triggered."
Sep 16 01:21:03 tmm tmm[7053]: Rule myrule1 : URI is /, default is triggered.
Sep 16 01:21:07 tmm tmm[7053]: Rule myrule1 : URI is /stuff, /stuff* is triggered.
Sep 16 01:21:14 tmm tmm[7053]: Rule myrule1 : URI is /stuff123, /stuff* is triggered.
Sep 16 01:21:19 tmm tmm[7053]: Rule myrule1 : URI is /stuff/place, /stuff/place* is triggered.
Sep 16 01:21:21 tmm tmm[7053]: Rule myrule1 : URI is /stuff/place123, /stuff/place* is triggered.
Your syntax actually looks just fine, you just need to combine the two with, as the above poster said, the more specific criteria first. Make sure you’re closing the switch cases, and you’re good to go.
Colin
Just to confirm, this worked! Thanks for all your help.
