alertd high cpu usage
Hello,
So we tried taxing the HSL logging of our 12.1.2 cluster with several (4) simple
while true; do curl http://virtual-ip/; done
curl loops. The virtual IP had a simple iRule that logged
[HTTP::request]
several times. Our logging is BSD syslog to HSL, to a logstash pool.
During our testing, we saw alertd rising to 100% CPU and maxing out there. CPU usage on the dashboard increased aswell, as you see in the image below.
sys log-config destination remote-high-speed-log elk-hsl-destination {
    pool-name syslog-pool
sys log-config destination remote-syslog rsyslog-to-hsl-elk {
sys log-config filter elk-hsl-filter {
    level info
    publisher elk-hsl-publisher
sys log-config publisher elk-hsl-publisher {
    destinations {
        rsyslog-to-hsl-elk { }
Any idea how we can combat this? We would like to use HSL to reduce CPU consumption, but this seems like a lot of fuss for simple logging. Ideas? Thanks!
This was because I was logging with
log local0.
