I have the following web farm setup in production server.
Browser --> HTTPS --> Load Balancer --> HTTP --> webserver node
F5 Load balancer handles off box SSL termination. It implies that SSL resides on F5 load balancer.
Problem Statement: Ajax calls do not go through unless “Access data sources across domains” option is enabled in IE security settings.
I have the similar setup in staging server except F5 Load balancer. The ASP.Net application makes perfect AJAX calls on both HTTP and HTTPS.
However, the staging server web farm use windows NLB and SSL resides on individual web server nodes.
hoolio
October 7, 2010, 4:30pm
2
Hi Saravanan,
I would suggest using a browser addon like HttpFox for Firefox or Fiddler for IE/FF to record the HTTP/S communication on the client. Once you have an exact understanding of what’s failing, you can start looking for a solution on LTM using config changes or an iRule.
Aaron
hi have same issue while AJAX in webpage is not working and redirect issue 302 i found using httpwatch
while clicking AJAX page on website we getting “error loading page” error
please help us resolve issue.
We have created http profile as per the article myF5 and WL plugin installed in oracle weblogic server then found working thanks
