We have migrated couple of our services from ACE to F5s. We have noticed on the servers that number of connections has increased rapidly. It doubled and even more. Since the ACE was in transparent mode it is little bit different than F5. We were thinking using OneConnect profile, but since the service is HTTPS, I am not sure how it will behave. There is no SSL offload on the F5. Does anyone have any idea ?
In theory, you can use oneconnect without an HTTP profile, or with traffic that is not HTTP. In practice, there are many limitations.
Read this solution, especially the recommendations part.
As the traffic is encrypted, and you are not decrypting in the F5, you can’t use an HTTP profile. That is because the F5 would never see the HTTP data, so traffic would not be sent to the pool members.
