AFM: Matching order between AFM rule and NAT
I have a question on AFM and matching order process between AFM Fw rule and LTM NAT.
When I create a new rule, which IP should I use ? Origin or translated IP ?
Best regards
Which NAT are you talking about ? If it’s SNAT applied on a VS, you don’t need to know it when you’re on AFM.
SNAT is applied when the packet is leaving out your BIG-IP.
Thank you for the feedback,
OK so for the SNAT when I create rule, I have to use the origin IP. Is it the same thing for destination NAT (create via LTM → NAT List + Create) ?
Best regards,
It’s the same for the NAT List, you have to use the “original” destination IP.
But be careful, it will be under Global level.
OK, we are agree.
Thanks a lot
