AFM: Block IPs from specific Country
i was wondering if it is possible to block all connections from IPs belonging to specific countries with AFM? I found some documents, which i understand as this should be possible, but I do not find any manual for this purpose.
Does anyone have a link or description for me how this works?
Thanks in advance!
Ralf
Here’s some discussion on an iRule solution that might help: DevCentral - An F5 Technical Community
Also, if you have the ASM provisioned, you can use the Geolocation feature to block IPs from specific countries. Here’s an article describing the ASM capabilities: DevCentral - An F5 Technical Community
