we’ve go a BigIP 5250 working as Load Balancer on production. The resources (CPU/RAM) on this device are very busy.
The problem we have is we have configured almost all the virtual server listening on HTTP, without SSL encryption.
We are planning to activate HTTPs (SSL) on some critical virtual server, but we are worry about the perfomance affectation of this over the device. It would be a disaster to lose the production service…
My question is, is there difference between configurate a secure cipher suite or a simplier one (like RC4 or similar)? In this way, Does it exist some kind of table where i can read the afectation of each cipher suite available to choose on the BIG-IP?
RC4 is not a secure Cipher suit , we have removed it long time back.
Yes You can see on SSL profile and can modify SSL cipher suites , normally it use default ones including RC4 and Others, You can modify it but make sure none of your server using these suites .
