AES256-SHA256 SSL Cipher Suite
I’m sorry if this question is trivial.
I was referring to 404 Page not found | BIG-IP Documentation and I would like to create new HTTPS monitor using AES256-SHA256. What should i put in the Cipher List?
I was guessing that it will be: DEFAULT:+SHA:+3DES:+kEDH:+AES256-SHA256: or DEFAULT:+SHA:+3DES:+kEDH:+AES:+SHA256. No?
BIG-IP 10.2.3
i understand bigd uses openssl cipher. i do not see sha256 in cipher list.
[root@ve10a:Active] config  tmsh show sys version|head
Sys::Version
Main Package
  Product  BIG-IP
  Version  10.2.4
  Build    855.0
  Edition  Hotfix HF9
  Date     Thu Oct  9 11:19:27 PDT 2014
Hotfix List
[root@ve10a:Active] config  openssl ciphers -v
DHE-RSA-AES256-SHA      SSLv3 Kx=DH       Au=RSA  Enc=AES(256)  Mac=SHA1
DHE-DSS-AES256-SHA      SSLv3 Kx=DH       Au=DSS  Enc=AES(256)  Mac=SHA1
AES256-SHA              SSLv3 Kx=RSA      Au=RSA  Enc=AES(256)  Mac=SHA1
EDH-RSA-DES-CBC3-SHA    SSLv3 Kx=DH       Au=RSA  Enc=3DES(168) Mac=SHA1
EDH-DSS-DES-CBC3-SHA    SSLv3 Kx=DH       Au=DSS  Enc=3DES(168) Mac=SHA1
DES-CBC3-SHA            SSLv3 Kx=RSA      Au=RSA  Enc=3DES(168) Mac=SHA1
DHE-RSA-AES128-SHA      SSLv3 Kx=DH       Au=RSA  Enc=AES(128)  Mac=SHA1
DHE-DSS-AES128-SHA      SSLv3 Kx=DH       Au=DSS  Enc=AES(128)  Mac=SHA1
AES128-SHA              SSLv3 Kx=RSA      Au=RSA  Enc=AES(128)  Mac=SHA1
RC4-SHA                 SSLv3 Kx=RSA      Au=RSA  Enc=RC4(128)  Mac=SHA1
I’m a little bit confused here.
[root@LORD:Active] ~  tmsh show sys version
Sys::Version
Main Package
  Product  BIG-IP
  Version  10.2.3
  Build    123.0
  Edition  Hotfix HF1
  Date     Fri Dec  2 11:43:17 PST 2011
Hotfix List
ID372804  ID372864  ID372590
[root@LORD:Active] ~  openssl ciphers -v
[root@LORD:Active] ~   tmm --clientciphers 'DEFAULT'
     ID SUITE                          BITS  PROT  METHOD CIPHER MAC    KEYX
 0:   5 RC4-SHA                         128  SSL3  Native RC4    SHA    RSA
 1:   5 RC4-SHA                         128  TLS1  Native RC4    SHA    RSA
 2:   5 RC4-SHA                         128  TLS1.2  Native RC4    SHA    RSA
 3:  47 AES128-SHA                      128  SSL3  Native AES    SHA    RSA
 4:  47 AES128-SHA                      128  TLS1  Native AES    SHA    RSA
 5:  47 AES128-SHA                      128  TLS1.2  Native AES    SHA    RSA
 6:  47 AES128-SHA                      128  DTLS1  Native AES    SHA    RSA
 7:  53 AES256-SHA                      256  SSL3  Native AES    SHA    RSA
 8:  53 AES256-SHA                      256  TLS1  Native AES    SHA    RSA
 9:  53 AES256-SHA                      256  TLS1.2  Native AES    SHA    RSA
10:  53 AES256-SHA                      256  DTLS1  Native AES    SHA    RSA
11:  10 DES-CBC3-SHA                    192  SSL3  Native DES    SHA    RSA
12:  10 DES-CBC3-SHA                    192  TLS1  Native DES    SHA    RSA
13:  10 DES-CBC3-SHA                    192  TLS1.2  Native DES    SHA    RSA
14:  10 DES-CBC3-SHA                    192  DTLS1  Native DES    SHA    RSA
15:  60 AES128-SHA256                   128  TLS1.2  Native AES    SHA256 RSA
16:  61 AES256-SHA256                   256  TLS1.2  Native AES    SHA256 RSA
i understand bigd does not use cipher from tmm (tmm --clientciphers).
Have u got the https monitor working for sha256?
Appreciate your response.
Regards, Midhun P.K
try opening a new question with what you tried and your BIG-IP version. also provide the input from openssl ciphers -v ?
