I need to remove the footer text (F5 license text) in the customization. I could only do it by changing (adv customization) the content of footer.inc (remove the variable). That variable cannot be set through the GUI. In which file is it set? I also have the same issue with the Web Portal. There is the variable “webtop_header_message” which is set to “Welcome to F5 Networks”, but I cannot change it through the GUI and haven’t found the file where it’s defined.
Can we set those variables through the VPE?
Thank you! Alexandre
For the footer:
Access Policy - Customization (Advanced) - Localization tab - Customization Settings - Access Profiles - [your profile] - Common - Page Footer Settings - Footer Text. Enter a blank space. If you just delete the value, it will still show up.
For the webtop:
Access Policy - Customization (Advanced) - Localization tab - Customization Settings - Webtops - [your webtop] - Full Webtop Settings - Header Message. Again, enter a blank space.
Hi, You can change it through Basic Customization → common page style → select AP - > Page Footer Setting (down the page) → Footer text box, change the text as you need
