ADFS 3.0 Install-WebApplicationProxy issue
We published ADFS 3.0 with success and we can authenticate Office 365 users now.
We decided to do SSL offload and re-encryption to treat SSLv3 (windows XP).
However, we are facing a problem installing the web proxy server between front-end and back-end servers in the powershell command line “Install-WebApplicationProxy”.
When we perform this installation passing through the BIGIP, the installation is not completed successfully, however, if we do the installation directly through the servers, it works.
The installation stops at some point that we can’t understand, but reaches transfer the self-signed certificate between the peers.
I’m no expert in AD FS, so, will that by doing the re-encryption of the data, lose some functionality of trust certificates to make this sync servers?
There is some step that should be enabled for this sync?
DevCentral https://technet.microsoft.com/en-us/library/dn283414.aspx
