Hi
I have a BIGIP load balancer which has two virtual server setup to a pool of servers. One for HTTP and the other for HTTPS.
Taking all but one server out of the pool to make diagnostics easier the result is the same. If I do a GET of an address over HTTP or HTTPS all is well.
However when doing a POST of a SOAP envelope (containg xml)to the HTTP address we get a valid response but if we try and POST the same SOAP envelope (containg xml)via HTTPS we get a 500 error on the node IIS log and the following message returned at the client:-
The message with To ‘https://reapatt.assureweb.co.uk/Ape2/BondComparisonService.svc/UNP’ cannot be processed at the receiver, due to an AddressFilter mismatch at the EndpointDispatcher. Check that the sender and receiver’s EndpointAddresses
Any help/pointers would be greatly appreicated.
Many Thanks,
JD
