Address Translation checkbox and Port Translation Box are only available for layer 2 ?
From Layer 2 nPath routing it says : For the Address Translation setting, clear the Enabled check box.
I could not find where the check box is.
I didn’t fully understand your request. If you are looking for “Address Translation” check box, look under Virtual Server setting.
