I’m interested in finding out more about using the OData $filter keyword to filter iControlREST API results. Jason’s article on iControl query params was a good starting point, but I’m getting errors when I try to filter on anything other than partition.
I’m running 11.6.0 Build 4.0.420 Hotfix HF4, and I realize that I might need to upgrade to get the features I want. However, according to the release notes for 12.0 (Fix ID 465197) this is a known issue and only filtering on partitioning is supported. This severely limits $filter’s usefulness. Anyone know of plans to expand $filter’s use?
Also, I’m wondering if any of the OData operators that would allow inexact/wildcard matches (startswith,endswith,substringof) have been implemented. For example, I’d really like to be able to filter all pool names that start with a certain sequence.
`[SEVERE][12150][11 Jun 2018 09:56:22 UTC][com.f5.rest.workers.asm.AsmConfigWorker] nanoTime:[18666043711136120] threadId:[20] Exception:[ASMConfigException(error_message:DBD::mysql::st execute failed: Unknown column 'policy_id' in 'group statement' at /usr/local/share/perl5/F5/ASMConfig/Entity/Base.pm line 1296., internal_error:DBD::mysql::st execute failed: Unknown column 'policy_id' in 'group statement' at /usr/local/share/perl5/F5/ASMConfig/Entity/Base.pm line 1296., rest_code:REST_INTERNAL_SERVER_ERROR)
at com.f5.asmconfig.ASMConfig$rest_call_result$rest_call_resultStandardScheme.read(ASMConfig.java:12388)
at com.f5.asmconfig.ASMConfig$rest_call_result$rest_call_resultStandardScheme.read(ASMConfig.java:12366)
at com.f5.asmconfig.ASMConfig$rest_call_result.read(ASMConfig.java:12308)
at org.apache.thrift.TServiceClient.receiveBase(TServiceClient.java:78)
at com.f5.asmconfig.ASMConfig$Client.recv_rest_call(ASMConfig.java:458)
at com.f5.asmconfig.ASMConfig$Client.rest_call(ASMConfig.java:443)
at com.f5.asmconfig.client.AsmClient.rest_call(AsmClient.java:61)
at com.f5.rest.workers.asm.AsmConfigWorker.restCallWithRetry(AsmConfigWorker.java:155)
at com.f5.rest.workers.asm.AsmConfigWorker.forwardCall(AsmConfigWorker.java:178)
at com.f5.rest.workers.asm.AsmConfigWorker$1.run(AsmConfigWorker.java:135)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
]client:[30938884]
]client:[30938884]
