Since we’re changing account names I need to create a lot of users on all of our BigIP systems. However my perl scripting is not succesful so far which has probably to do with the way I pass data to the call -- yes I’m clueless --. I try with this snippet of code:
$soap = SOAP::Lite
→ uri(‘urn:iControl:Management/UserManagement’)
→ readable(1)
→ proxy(“$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi”);
eval {
$soap->transport->http_request->header
‘Authorization’ =>
'Basic ’ . MIME::Base64::encode(“$sUID:$sPWD”, ‘’)
$user{‘name’} = “tester1”;
$user{‘full_name’} = “tester1 123”;
$UserInfo{‘user’} = $user;
$UserInfo{‘role’} = 0;
$UserInfo{‘password’} = “*LCK*”;
$UserInfo{‘home_directory’} = “/home/tester1”;
$UserInfo{‘login_shell’} = “/bin/bash”;
$UserInfo{‘user_id’} = 0;
$UserInfo{‘group_id’} = 500;
$users[$i++] = $UserInfo;
$soapResponse = $soap->create_user(
SOAP::Data->name(
‘users’ => @users
I can see in my logs that iControl receives the call. However no user is created. My tcpdump is not showing the XML i expected as well (no user name, etc)
Some helpful hints would be more then welcome
Cheers
Marcel
Ah, found some sample code on this forum, but I still can’t get it to work. Code now looks like:
$userid = {name => “tester1”, full_name => “Marcel Kuiper”};
@userinfo = (
user => $userid,
role => “USER_ROLE_ADMINISTRATOR”,
password => “*LCK*”,
home_directory => “/home/tester1”,
login_shell => “/bin/bash”,
user_id => 0,
group_id => 500
my $soapResponse = $soap->create_user(
SOAP::Data->name(users => [@userinfo])->type(“UserInfo[]”)
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, “\n”;
Great! Please post again if anything else comes up.
-Joe
I am trying to do the same thing in powershell. I am able to following:
$ic = Get-F5.IControl
and invoke the method
$ic.ManagementUserManagement.create_user() but I need to pass in an object of type UserInfo
How do I create an object of this type?
Ahh, some fun PowerShell stuff!
For the methods that require typed structures, you need to create them with the “New-Object” Cmdlet. Here’s how you would make a call to create_user()
$ic = Get-F5.iControl
$userInfo = New-Object -TypeName iControl.ManagementUserManagementUserInfo
$userInfo.user = New-Object -TypeName iControl.ManagementUserManagementUserID
$userInfo.user.name = "testaccount"
$userInfo.user.full_name = "Joe User"
$userInfo.role = "USER_ROLE_ADMINISTRATOR"
$userInfo.password = "foobar"
$userInfo.home_directory = "/home/joeuser"
$userInfo.login_shell = "/bin/bash"
$userInfo.user_id = 0
$userInfo.group_id = 500
$ic.ManagementUserManagement.create_user( (,$userInfo) )
You’ll notice that the method takes an array, so the paramter is surounded by parenthesis and prefixed with a comma to indicate the creation of an array.
Hope this helps…
-Joe
Thanks Joe, that works great.
Another question how do I set the users console access? Users created with the above process have console access enabled, I don’t want that for our operators.
Sorry I guess I needed to be more clear. The $userinfo.role = USER_ROLE_TRAFFIC_MANAGER still grants Console access. ie I create this user and then go to the Web GUI and the user has console access enabled. I don’t really want to hack it and set the login_shell to something false.
I want to set the correct value so that if an admin in the GUI wanted to change it they would just have to uncheck the box.
Actually, From what I can tell, the The GUI just changes the login shell depending on what you have selected for Console Access
Disabled => /bin/false
Advanced Shell => /bin/bash
bigpipe Shell => /bin/bpsh
The following PowerShell code should work for setting the shell
$um = $ic.ManagementUserManagement
$um.set_login_shell( (,"joeuser"), (,"/bin/false") )
This should disable console access for user “joeuser”.
-Joe
Thanks for the confirmation joe
Quick question - what is the significance of “user_id” and “group_id” ? Is there documentation that I could search for quesitons like these as opposed to asking in the forums, so I don’t have to bug you guys?
Luke,
If you are unfamiliar with UNIX/Linux: user_id and group_id are UNIX-specific identifiers as the F5 host system is Linux-based, BUT, the please do read the note on create_user method in v10.1 SDK:
Note: this method is deprecated; please use create_user_3 and associated data. (home directory, user id, and group id are now computed by the system) Note: as of v10.1.0, this method will silently ignore any of user id, group id, and home directory passed in.
i.e. you don’t have to worry about user_id/group_id and home_directory anymore if you are running version 10.1+
Sam
