So I need some help with the syntax of an irule. Here is what we are trying to do:
We have 2 pools, pool 1 is for the primary/static website www.abc.com and pool 2 is for backend applications such as www.abc.com/link/*. There is only 1 VIP IP associated with pool 1. My goal is to create an irule to tell the BIGIP to redirect any http requests to www.abc.com/link* to pool 2.
Here is the syntax I have so far, however the problem I’ve run into is that I need to find a way to put the * at the end to signify that anything past this point does not need to match and can be included in the redirect:
set uri [string tolower [HTTP::uri]]
if { $uri ends_with “eventlogscan/” } {
pool App_pool
} elseif { $uri starts_with “/www.gfi” } {
pool Web_Deck_pool
Any help would be appreciated.
