I have been able to add VIPs and Pools, but not having success adding nodes. I know I’m close. Any clue what I’m missing? I know the various values are getting to the function. I believe the issue is with the function. Any help is appreciated, Thanks. Here’s my sample code:
!/usr/bin/perl
use REST::Client;
use MIME::Base64;
use JSON;
$F5User=‘username’;
$F5Pass=‘password’;
$User=‘jsmith’;
$LTM=“ltm.domain.com”;
$PoolMember1 = “172.22.99.100”;
$PoolMember2 = “172.22.99.101”;
$ConnectionLimit1 = “0”;
$ConnectionLimit2 = “0”;
$Ratio1 = “1”;
$Ratio2 = “1”;
$Ticket = “11-123”;
my $bigip = REST::Client->new();
$bigip->addHeader(‘Content-Type’, ‘application/json’);
$bigip->addHeader(‘Authorization’, 'Basic ’ . encode_base64($F5User . ‘:’ . $F5Pass));
$bigip->setHost(‘https://’ . $LTM . ‘/mgmt/tm’);
$NODE_STRING = “$PoolMember1:$ConnectionLimit1:$Ratio1,$PoolMember2:$ConnectionLimit2:$Ratio2”;
@NODE_MEMBERS = split(‘,’,$NODE_STRING);
&create_node($bigip, $User, [@NODE_MEMBERS], $Ticket);
sub create_node {
my ($bigip, $User, $name, $Ticket) = @_;
$now = localtime();
convert member format
foreach $node(@$name) {
($address, $ConnectionLimit, $Ratio) = split(':',$node);
define node properties
my %payload;
$payload{'kind'} = 'tm:ltm:node:nodestate';
$payload{'name'} = $address;
$payload{'description'} = 'Created by: ' . $User . ' via web page on ' . $now . ' as per ' . $Ticket;
$payload{'connectionLimit'} = $ConnectionLimit;
$payload{'ratio'} = $Ratio;
my $json = encode_json \%payload;
$bigip->POST('ltm/node', $json);
} End foreach $node
} End create_node
