I am trying to add custom metadata to a virtual address using pycontrol. None of my calls fail, but
get_metadata
always returns an empty list. Here is my program:
from pycontrol import pycontrol
bigip = pycontrol.BIGIP(
hostname='my-lb.example.net',
username='admin',
password='******',
fromurl=True,
wsdls=['LocalLB.VirtualAddressV2'])
Any virtual address shows the same behavior
vip = bigip.LocalLB.VirtualAddressV2.get_list()[0]
bigip.LocalLB.VirtualAddressV2.add_metadata([vip], [['owner']], [['daryll']])
meta = bigip.LocalLB.VirtualAddressV2.get_metadata([vip])
print "%r" % (meta,)
The output of the program is
. I have tried using an administrator account with the same results. Any tips would be appreciated. My BigIP is at version 11.4 and I am using pycontrol 2.1.
I’m using bigsuds instead of pycontrol, but I was able to get the following to work on 11.3 and 11.5.3.
import bigsuds
b = bigsuds.BIGIP(hostname='1.2.3.4')
vip = b.LocalLB.VirtualAddressV2.get_list()[0]
b.LocalLB.VirtualAddressV2.add_metadata([vip], [['owner']], [['daryll']])
vip_metadata = b.LocalLB.VirtualAddressV2.get_metadata([vip])
for meta_data in vip_metadata:
print b.LocalLB.VirtualAddressV2.get_metadata_value([vip],[[meta_data]])
If you are at the CLI of the bigip and run ‘tmsh save sys config’, then you should see metadata attached to the vip. Something like this in /config/bipip.conf:
ltm virtual-address /Common/192.168.1.41 {
address 192.168.1.41
mask 255.255.255.255
metadata {
owner {
value daryll
Perhaps there is an issue with pycontrol? I used only bigsuds. Please let me know how that works out for you.
-Kelly
Thank you. This indeed worked when I switched to the bigsuds library. The API is similar enough that it is less work for me to port my code to bigsuds than diagnose the issue with pycontrol.
