Hello!,
I am trying to create a new external monitor using command:
tmsh create ltm monitor external test defaults-from external run /config/monitors/test
But always get the following error:
0107134a:3: File object by name (/config/monitors/test) is missing.
Could someone help?
Thanks!!
Hi Carlos,
for bigip versions 10.1.0 - 10.2.4, external monitors are to be configured in /config/monitors directory. So, can you try by just giving the file name instead of the path ?
something like: tmsh create ltm monitor external test defaults-from external run test
- Santosh
Hi Santosh,
thanks for your help.
I am working with version 11.
Finally, I found the mistake, I used a wrong name loading the file-name in the webinterface.
