adding a new interface, selfIP and VIP
I’ve been trying to follow instructions and setup a new interface, selfip and VIP (on the selfip network) and i cant get it to work…
my attempt looks like this:
i’ve been following:
I had the new NIC added to the BigIP VirtualMachine, then i ran
rm –f /var/db/mcpdb*
touch /service/mcpd/forceload
then restarted the box
then ran
f5-swap-eth -w
cat /etc/ethmap
the cat command showed an additional MAC address which i assume was the one that was added (hard to verify)
then i tried to map in a new interface like this:
net self /Common/SomeSelfIp {
address x.x.x.x/24
traffic-group /Common/traffic-group-local-only
vlan /Common/SomeVLAN
net vlan /Common/SomeVLAN {
interfaces {
1.9 { }
tag xxx
however from another machcine on the x.x.x.x/24 network i cant ping this interface..
is there something else i need to do to get it come up?
Port lockdown might be a consideration but it shouldn’t impact ICMP traffic (ping).
Are you sure you’re using the right physical interface assigned to the vlan?
