I have two F5s in a HA pair. When I add the cert and key, do I only need to do the import on one of the two devices and then it will sync to the other device?
Hello.
These are the object which are not synchronised between HA members
KR,
Dario.
Thanks Dario
I am referring to a certificate and a key that will be used in SSL profile. I am not sure if I have to import the certificate and key on each F5 in the pair, and then associate that certificate and key to the client and server ssl profiles, or if I only need to do the import on a single F5 in the HA pair.
Thanks!
Eric
Hello EricTTEC.
System certificates are not sync between HA pairs.
- GUI interfaces
- iQuery GTM
- DSC
SSL profile certificates yes, they are sync.
KR,
Dario.
