Hi guys.
recently I have a customer using v9.3.1 and I have to add pool member.
I tried to install 9.3.1 on bigip 1600 but I failed all.
So I test on 9.4.8 on bigip 1600
using below command are well work.
b pool test { monitor all tcp }-> work b pool test member 10.10.10.10:80 add-> work b pool test member 10.10.10.10:80 { session disable }-> work b pool test member 10.10.10.11:80 { session disable } add → work
I`m afraid of these command would be work on 9.3.1
current v9.3.1 is out of support.
does anyone know some information?
In fact t v9.3.1 is out of support. And I checked on F5 docs without success.
Why you don’t upgrade, when you check “The BIG-IP release matrix” you can see that 1600 support 12.1.2.
I advise you to upgrade in order to use tmsh that are documented and supported.
is there a reason you do not want to upgrade. we can help you for that if you wish.
Regards,
b pool test { monitor all tcp } -> work
b pool test member 10.10.10.10:80 add -> work
b pool test member 10.10.10.10:80 { session disable } -> work
b pool test member 10.10.10.11:80 { session disable } add -> work
I would expect those commands to work in the bigpipe shell on v9.3.1, but I would verify that your pool has two members when you’re finished. I suspect (but may not be correct, it’s been a really long time) that you’ll only have the 10.10.10.11:80 pool member.
Here’s few b commands I had saved once,
b pool list --> tmsh list /ltm pool
b pool mypool member 192.168.0.1:80 add --> tmsh modify /ltm pool mypool members add { 192.168.0.1:80 }
b pool mypool member 10.10.10.10:80 down --> (10.2.4) tmsh modify ltm pool mypool members modify { 10.10.10.10:80 { state down } } | (v11.x) tmsh modify ltm pool mypool members modify { 10.10.10.10:80 { state user-down } }
b pool show --> tmsh show /ltm pool members
When I used 9.x, i used to follow the below method, single quotes, give your inputs and run it, it will get appended.
b pool pool_name'{
monitor all pool_dummy
members
10.10.10.10:80 { session user disabled }
