Hey Team,
I encountered some issues on the cluster of the LB if I add FQDN Nodes to the pool.
As per F5 support we have to add the nodes to the pool with the Auto Populate Enable since that can cause problems.
I am trying to find a way when we add the nodes with that feature on however i am not able to find it
This is my code
def add_node_to_pool(self, node_name, pool_name, port_number):
# method to add node to the pool created
my_pool_add = self.mgmt.tm.ltm.pools.pool.load(name=pool_name)
my_pool_add.members_s.members.create(partition=‘Common’, name=node_name + ‘:’ + port_number)
my_pool_add.update()
print('Node ’ + node_name + ’ added to pool ’ + pool_name)
