add a member to a external data group with a perl script.
I want to write a perl script which adds a member to a external data group. New members are included in a text file that:
x.txt
AAAA;external_data
AAAA is a new member. but I do not want to lose old members also. so I wrote a perl script that is in below.
after running perl script, external_data group file would be :
“AAAA”,
IlZWVlYiLA==
As a result, the txt data is written normally but old data is written by a different format.
I want to run script in f5, so I must use perl script.
Please help me.
Thanks.
!/usr/bin/perl
use SOAP::Lite;
use integer;
sub listStrings
sub listStrings()
open(FILE, ‘x.txt’) or die “Can not read file!”; datagroup okundu
my $data_file = ‘/etc/hys/temp.txt’;
open TEMPFILE, “>$data_file” or die “can’t open $data_file $!”;
binmode(TEMPFILE);
while () {
chomp; no newline
s/.*//; no comments
s/^\s+//; no leading white
s/\s+$//; no trailing white
next unless length; anything left?
my ($var, $value) = split(/\s*;\s*/, $_, 2);
$sclass_members = $var;
$sdata_group = $value;
$sclass_members = “\”" . “$sclass_members” . “\”,";
$soapResponse = $Class->get_external_class_file_name
SOAP::Data->name(class_names => [$sdata_group])
@file_names = @{$soapResponse->result};
$fileName = @file_names[0];
$chain_type = $FILE_FIRST;
$chunk_size = 65536;
$file_offset = 0;
print TEMPFILE “$sclass_members\n”;
$StringClass =
name => $sdata_group,
members => [$sclass_members]
my ($class, $string) = (@_);
$StringClass =
$soap_response = $ConfigSync->download_file
SOAP::Data->name(file_name => $fileName),
SOAP::Data->name(chunk_size => $chunk_size),
SOAP::Data->name(file_offset => $file_offset)
$FileTransferContext = $soap_response->result;
$file_data = $FileTransferContext->{“file_data”};
$chain_type = $FileTransferContext->{“chain_type”};
@params = $soap_response->paramsout;
$file_offset = @params[0];
Append Data to File
print TEMPFILE $file_data;
close (TEMPFILE);
open(TEMPFILE, “<$data_file”) or die(“Can’t open $localFile for input: $!”);
binmode(TEMPFILE);
$file_data = “”;
$bytes_read = read(TEMPFILE, $file_data, $chunk_size);
file_data => SOAP::Data->type(base64 => $file_data),
chain_type => $chain_type
$soap_response = $ConfigSync->upload_file
SOAP::Data->name(file_context => $FileTransferContext)
if ( $soap_response->fault )
print $soap_response->faultcode, " ", $soap_response->faultstring, “$file_data $chain_type\n”;
close (TEMPFILE);
close(FILE);
$ConfigSync->load_configuration(“/config/bigip.conf”, 0);
You are on the right track. With external data groups you need to treat them like flies and use the ConfigSync download/upload_file commands and edit the file contents locally. The logic is really up to you on how you manipulate the content of the file when you have it locally. Check out the PerlConfigSync sample in the iControl codeshare on how to download/upload files.
-Joe
