Can some help me with a trivial thing, I would like to simply add a comment just before tag to any HTTP response going out off the F5 . How do I do that?
I am a beginner so excuse my ignorance
AS,
See wiki entry here: DevCentral (Insert Content Into Server Response).
However, Hoolio makes the point whether you need to HTTP::collect first and I tend to agree.
This wiki should help: DevCentral
Hope this helps,
N
You could also do this more efficiently using a stream profile versus buffering the full payload with HTTP::collect. You’d need to add a blank stream profile and a custom HTTP profile with response chunking set to rechunk.
Javascript to inject in text responses (wrap in curly braces to avoid having to escape meta-characters).
set js {my javascript goes here...}
Disable the stream filter by default
STREAM::disable
when HTTP_RESPONSE {
Check for text responses
if {[HTTP::header value Content-Type] contains "text"} {
Replace closing tag with $js
STREAM::expression "@@$js@"
STREAM::enable
Aaron
