AD Query not working - Edge v11.0
Hi guys … in a major pickle here…
I have followed this guide but still can’t get this working.
This is what’s being logged in /var/log/apm
Sep 22 14:06:56 edge01 info apd[20821]: 01490006:6: 5a8f9d35: Following rule ‘Successful’ from item ‘AD Auth’ to item ‘AD Query’
Sep 22 14:06:56 edge01 debug apd[20821]: 01490011:7: 5a8f9d35: AD agent: ENTER Function executeInstance
Sep 22 14:06:56 edge01 debug apd[20821]: 01490000:7: ./AccessPolicyProcessor/Session.h func: “getSessionVar()” line: 240 Msg: variable “session.logon.last.domain” was not found in the local cache for session “5a8f9d35”
Sep 22 14:06:56 edge01 debug apd[20821]: 01490000:7: ./AccessPolicyProcessor/Session.h func: “getSessionVar()” line: 247 Msg: try to get it from MEMCACHED
Sep 22 14:06:56 edge01 debug apd[20821]: 01490000:7: memcache.c func: “mc_convert_session_var_to_mc_key()” line: 831 Msg: Converted Var: session.logon.last.domain to Session Var tmm.session.5a8f9d35.session.logon.last.domain
Sep 22 14:06:56 edge01 debug apd[20821]: 01490000:7: ./AccessPolicyProcessor/Session.h func: “getSessionVar()” line: 262 Msg: variable “session.logon.last.domain” for session “5a8f9d35” was not found in MEMCACHED
Sep 22 14:06:56 edge01 debug apd[20821]: 01490023:7: 5a8f9d35: AD module: ENTER Function queryActiveDirectory
Sep 22 14:06:56 edge01 debug apd[20821]: 01490111:7: 5a8f9d35: AD module: verifyKrb5Cache(): Ticket cache: FILE:/var/run/krb5cc/Common/subdomain.domain.com_vip/krb5cc_0 Default principal: sc_edgegateway_ema@subdomain.domain.COM
Sep 22 14:06:56 edge01 debug apd[20821]: 01490111:7: 5a8f9d35: AD module: verifyKrb5Cache(): server realm:subdomain.domain.COM princ realm:subdomain.domain.COM server data[0]:krbtgt server data[1]:subdomain.domain.COM curr time: 1316700416 end time: 1316728077 Default principal: sc_edgegateway_ema@subdomain.domain.COM
Sep 22 14:06:56 edge01 debug apd[20821]: 01490027:7: 5a8f9d35: AD module: ldap_initialize() successful. URI:‘ldap://10.236.64.50:389’
Sep 22 14:06:56 edge01 debug apd[20821]: 01490029:7: 5a8f9d35: AD module: ldap_sasl_interactive_bind_s() successful.
Sep 22 14:06:56 edge01 debug apd[20821]: 01490023:7: 5a8f9d35: AD module: ENTER Function queryActiveDirectoryUser
Sep 22 14:06:56 edge01 debug apd[20821]: 01490024:7: 5a8f9d35: AD module: LEAVE Function queryActiveDirectoryUser
Sep 22 14:06:56 edge01 err apd[20821]: 01490107:3: 5a8f9d35: AD module: query with ‘(sAMAccountName=demastout)’ failed: Operations error, base: dc=subdomain,dc=domain,dc=COM, scope: 2, filter: (sAMAccountName=demastout) (1)
Sep 22 14:06:56 edge01 debug apd[20821]: 01490111:7: 5a8f9d35: AD module: ldap_search_ext_s(): Operations error, base: dc=subdomain,dc=domain,dc=COM, scope: 2, filter: (sAMAccountName=demastout) (1)
Sep 22 14:06:56 edge01 info apd[20821]: 01490019:6: 5a8f9d35: AD agent: Query: query with ‘(sAMAccountName=demastout)’ failed
Sep 22 14:06:56 edge01 debug apd[20821]: 01490012:7: 5a8f9d35: AD agent: LEAVE Function executeInstance
Sep 22 14:06:56 edge01 info apd[20821]: 01490004:6: 5a8f9d35: Executed agent ‘/Common/Remote_Access_Default_act_active_directory_query_ag’, return value 0
Sep 22 14:06:56 edge01 debug apd[20821]: 01490000:7: ./AccessPolicyProcessor/SessionState.h func: “clearTempSessionAgentState()” line: 82 Msg: Agent did not initiated the scheduled agent
Sep 22 14:06:56 edge01 debug apd[20821]: 01490000:7: AccessPolicyProcessor/AccessPolicy.cpp func: “execute()” line: 267 Msg: Let’s evaluate rules, total number of rules for this action=4
Sep 22 14:06:56 edge01 debug apd[20821]: 01490000:7: AccessPolicyProcessor/AccessPolicy.cpp func: “execute()” line: 273 Msg: Rule to evaluate = “expr { [mcget {session.ad.last.attr.memberOf}] contains “CN=subdomain Network Engineers,OU=GHC Groups,OU=EMA Hosting Centre,DC=subdomain,DC=domain,DC=com” }”
Authentication works … just matching the useraccount against a group fails. I’m new to this product so any help appreciated.
Regards,
Dave
Can you post your exact query string?
If you can’t post it, attempt to do this test via command line.
What happens when you run the ad test via command line?
ERROR: query with ‘(sAMAccountName=demastout)’ failed: Operations error, base: dc=XXXX,dc=DELOITTE,dc=COM, scope: 2, filter: (sAMAccountName=demastout) (1)
Test done: total tests: 1, success=0, failure=1
I think I am going to go back to the AD team and ask some questions. I don’t think it’s what i’m doing on the F5. I have a feeling they didn’t set up the service account correctly. … Unless you have any more ideas ?
That’s a good idea but if you have another known valid account you can test with the ad query tool and see if it will work.
