Issue: AD module: authentication with ‘domainname\username’ failed: Client ‘domainname\username@DOMAINNAME’ not found in Kerberos database, principal name: domainname\username@DOMAINNAME. Please verify Active Directory and DNS configuration .
External link connected via :Open network->system → Excel file → Data → From Database → From Analysis Services ( used for External link https://xxxxx.xx.com with username “Domain/Username”)
with out APM the application working successfully , but we enable the APM the AD module Failed , due to “domain/username” .
please let us know any solution for the APM end to remove the “Domain”?
Note: Internal link is required the “Domain/username”
