Actual Client IP and Proxy IP in X-Forwarded-For
We have a setup where clients are behind proxy and proxy is the src-ip for LTM, we have enabled X-Forwarded-For and we are getting Proxy-IP in the header, but now the requirement is to have actual client IP as well in the header(Client-IP,Proxy1-IP).
I have enabled the X-forwarded-for on the proxy, but still it seems that the LB is replacing the header with the latest one(proxy-ip)
Please suggest how to get both IP’s in the header.
Hi Ganesh,
to consolidate multiple occourences of
X-Forwarded-For
headers, you may try the iRule below…
    if { [set x_forwarded [HTTP::header values "X-Forwarded-For"]] ne "" } then {
        HTTP::header remove "X-Forwarded-For"
        HTTP::header insert "X-Forwarded-For" "[join $x_forwarded ", "], [getfield [IP::client_addr] "%" 1]"
        HTTP::header insert "X-Forwarded-For" "[getfield [IP::client_addr] "%" 1]"
The iRule will collect any existing X-Forwarded-For header values, then remove any existing X-Forwarded-For headers and finally create a new one with the collected values + the current “X-Forwarded-For” value. E.g.:
Incomming HTTP request headers
GET / HTTP/1.1
Host: site.domain.de
X-Forwarded-For: 1.1.1.1
X-Forwarded-For: 2.2.2.2, 3.3.3.3
X-Forwarded-For: 4.4.4.4
Outgoing HTTP request headers
GET / HTTP/1.1
X-Forwarded-For: 1.1.1.1, 2.2.2.2, 3.3.3.3, 4.4.4.4, 5.5.5.5
Note: Make sure to disable the automatic X-Forwarded-For insert option in your HTTP profile. The insert will be already handled by this iRule…
Cheers, Kai
Would the following fix this for you?
In Configuration Utility go:
  • Local Traffic ›› Profiles : Services : HTTP ›› your_http_profile
  • and tick the box for “Accept XFF”
  • Fill the field of “XFF Alternative Names”
Hi Ganesh,
I’ve just checked the provided iRule and it works for me. Please use the iRule below to troubleshoot the issue and post back the resulting logs…
    log local0.debug "Orig XFF: [HTTP::header values "X-Forwarded-For"]"
    log local0.debug "New XFF: [HTTP::header values "X-Forwarded-For"]"
Note: Also make sure, theoption of your attached HTTP profile is set to.
Insert X-Forwarded-For
disable
Cheers, Kai
