Is there a way to know the active users that have initiated a session into F5? I have tried logging into the device trough ssh and putting 'who' command, but it does not show users logged in Web GUI...
Many thanks in advance Leo
Leo
Check /var/log/audit for logons. if you use the following command you should see who’s logged in:
cat /var/log/audit | grep user=
N
Thanks guys for the quick reply. So I supposed there’s no way to check it quickly through the GUI… I’ll try your suggestions and take that one that fix better my needs ![]()
tail -f 500 /var/log/audit | grep “mod_auth_pam”
