Hello All
I am having an LTM running an Ver 10.2.1 , we have one Virtual server for both Active Sync and OWA access, The pool have 5 servers in total lisening on port 443.
Persistence - cookie Load balancing - Least connection (member)
The pool member stats are bit odd
Server 1 and Server 3 are having very low current connection i.e 200 - 300 connection
Where as the other servers has 1.5K - 1.8K
Please could some one provide some ideas to get the load balaning more effective
Use Least sessions LB algo and please let us know what you see.
Thanks Nikhil
But I found a doc stating “Note: The Least Sessions methods are incompatible with cookie persistence.” We use Cookie persistence
apologies, didnt realize you were using cookie persistence. Have you tried the default round robin and checked the results? 404 Page not found | BIG-IP Documentation
No worries!
We have tried round robin before
Please can I get an input on the above issue i am seeing
Do you have snat configured? Assuming you also have one connect on? Have yo tried disabling persistence and seeing the results?`
Yes we do have snat configure , no Oneconnect profile.
I havent tried removing the Cookie persistance - we are using an HTTP insert Cookie and Session cookie is CHECKED
