is there any KB that shows how to make an active/passive scenario to active/active?
what will be the impact?
As far as I know the only way to have an active/active pair on F5 is to have 2 separate traffic groups, each ideally containing half of your Failover Objects.
Traffic group 1 would have device A as Active and device B as Standby
Traffic group 2 would have device B as Active and device A as Standby
So to transition from Active/Standby to Active/Active, you’d need to first create another traffic group using Failover Method “HA Order,” then cutover half of your Failover Objects to the other traffic group during a maintenance window. But Active/Standby is the preferred/recommended approach… Not sure about a KB for this either.
