active directory ldap monitor
AAA activedirectory ldap monitor
Server pool monitor activedirectory
I do not know the procedure to change keep alive from icmp to ldap
K17472: Overview of LDAP Monitoring
Thank you very much. Should I create an Ldap Monitor for LocalTraffuc → monitor? Next, is the AAA server Active Directory where the LdapMonior is specified? Or will it be POOL’s ActiveDirectrySVs? Thank you. Also, is the user specified with Filer CN = User 1 in the sample the same as the user specified with UserName CN =? Thank you.
you create the monitor at local traffic > monitors
you apply it at local traffic > pools or if you are using APM then at the AAA server > Server Pool Monitor
user can be in normal mode, so without cn=, ..dc=.. it used if authtentication towards LDAP is needed
at filter you can enter a specific ldap key to look for in the LDAP
i would with start keeping it simple before going further.
