Active Directory date long integer pwdLastSet conversion
Is there a way to convert this long integer value (pwdLastSet) from AD into a readable date using an iRule?
Hi Steve,
The pwdLastSet value is basically the number of 100 nanosecond intervals since January 1, 1601 (UTC). So yes, there is a way.
The following probably isn’t fully ‘copy-pastable’ to an iRule, but it’ll give you the idea:
http://wiki.tcl.tk/1827
Greets,
Thomas Schockaert
