Customer is running active/active configurations and they found the following behavior. Are they normal?
1. for each VLAN on BIG-IP, unit 1 is not able to ping the floating ip of unit 2, and vice versa. unit 1 is able to ping its own floating ip and physical ip of both units.
2. vs1 is active on unit 1 and vs2 active on unit 2. both vs on vlan-a. A client, which is on vlan-b, has default gateway pointing to unit 1. It is not able to access vs2. vlan-a and vlan-b are both on BIG-IP.
Yes, this happens with active/standby pairs as well if the packet is forwarded through the system. It’s similar to firewall anti-spoofing measures, where “in and out” on the same interface is blocked.
I find that active/active is very rarely worth the complexity it causes.
Denny
Thanks for your reply. I assume what you say is that pinging from unit 1 to floating ip of unit 2 causes “in and out” on the same interface. But why pinging its own floating ip is ok? What’s the difference?
