ACL matches per rule Context(Enforced) on F5 ASM
Hi All, When I go to
F5 >> Security ›› Reporting : Network : Enforced Rules ACL matches per rule Context(Enforced).
It shows Virtual Server622,780 Global111,203
AggregatedSelf IP1,336
/Common/BRIDGE-VLAN-GROUP_self_ipSelf IP603
/Common/App_x.x.x.x_VIPVirtual Server2
OverallN/A733,645
These are ACL matches per rule context.Please explain where is ACL and how this value depends on it.
Do you have AFM provisioned as well? it sounds like you do. if you see below the graph there should be a details section. keep clicking down further on the blue highlighted item to find the AFM ACL. you could either have AFM configured global context or on a per VS with rules
@jgranieri is on track here.
  1. Looking at the path you mention, you can see I bolded Network with is an AFM indicator.
Also the division of the context into the catagories you identified is also AFM terminology: Various contexts include Context is processed in this order:
  1. > Global
  2. > Route domain
  3. > Virtual server/self IP
  4. > Management port*
  5. > Global reject*
Depending on version, you can find this information on askf5 Firewall Context info
