ACE to LTM probe/monitor hash equivalent?
Hello All,
Recently we moved from our ace’s to f5’s for the loadbalancing. Everything works fine but have one issue at the moment i can’t seem to figure out. On the ace we had a hash check on our probe to see if the content of the checked-page is changes. Ifso → Down. On the F5’s I can’t seem to figure it out..
Our health monitors at the moment look like:
Send string GET /something/loadbalancer.html HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n
Receive String 200 OK
The problem with this is if IIS has a custom 503 error page for example it still receives a 200 OK.. so he thinks it is still alive.
Thanks in advanced for thinking with me.
Why do you not change the content of “receive string” to something that exists only when is a real successful request (e.g. welcome, hello)? Otherwise, you can flag the monitor as reverse and set “Error” in the receive string value. This field is a regex, so, you can do something more complex.
Just some tips, Regards
