Hi All,
I am new to F5 technology.. so I am not aware if its a common behaviour of F5.
1. I have configured my Load Balancers to work in Active/standby state. but both the devices are always in active state.
Now, When I click force standby on secondary unit of LB, I lose access to device for few seconds. but when it comes up, Its again active.
Please tell me how should I cpme out of this situation.
sounds like something is not correctly configured.
which version of TMOS 10 or 11? in case of 11 have you configured a device group? what are the Redundancy State Preferences?
Its 10.2.1 build 249
redundant stae preference is set to standby on Standby unit but its is still active.
nitass
August 14, 2012, 2:48pm
4
is unicast address for network failover setting correct?
Specifying unicast addresses for failover
When specifying unicast, rather than multicast, addresses for failover, you need to specify two pairs of IP addresses, where one of the pairs indicates the management IP addresses of the two units. The other pair indicates two self IP addresses, one for VLAN HA on each unit.
Configuring High Availability
yes..
actually, we are not using management interface on LTMs. We are accessing these throughinternal VLAN self IP addresses.
So In HA, I have specified these addresses and HA VLAN self IP addresses. I have confirmed that they are correctly configured.
any updates from anybody please?
nitass
August 21, 2012, 10:43am
7
can you post “b failover list” and “b mgmt list” output from both units?
Load Balancer LB002
[root@ULFINPG-LB002:Active] config b failover list
failover {
force standby enable
network failover enable
peer mgmt addr 10.255.155.3
redundant enable
standby link down time 5
unit 2
unicast peer SYNC {
dest addr 10.255.155.3
port 1026
source addr 10.255.155.4
Load Balancer LB001
[root@ULFINPG-LB001:Active] config b failover list
failover {
force active enable
peer mgmt addr 10.255.155.4
redundant enable
unit 1
unicast peer SYNC {
dest addr 10.255.155.4
port 1026
source addr 10.255.155.3
nitass
August 21, 2012, 11:15am
9
can you try to use mgmt ip in peer mgmt addr?
we are not using saperate management addresses.
We are accessing the device through VLAN self IP addresses.
nitass
August 21, 2012, 11:31am
11
We are accessing the device through VLAN self IP addresses.yes, i know but i understand peer mgmt addr has to be mgmt ip i.e. not selfip. can you try?
you mean, assigning dummy IP addresses to mgmt interface..? but these would not be physically connected anyway…
nitass
August 21, 2012, 11:45am
13
you mean, assigning dummy IP addresses to mgmt interface..? but these would not be physically connected anyway…yes please.
It wont be possible…
Even if I assign the IP addresses to mgmt IP addresses, I will not be able to get them physically connected.
nitass
August 21, 2012, 12:17pm
15
if i do not misremember, i think it is okay even it is not physically connected.
I have lost the access to both the devices after I added the IP address to Load Balancers.
nitass
August 21, 2012, 12:36pm
17
I have lost the access to both the devices after I added the IP address to Load Balancers.what ip did you use? it was not in any existing subnet, was it?
no it was not from any existing range
nitass
August 21, 2012, 12:51pm
19
so, have you got access back? are they still active/active??
not yet.. I do not have the console to these devices…
